How do I get the grill off my SVS sub?
Discussion in 'Speakers' started by Josh Wolfman, Jun 27, 2006.
  1. Josh Wolfman
    Josh Wolfman Stunt Coordinator
    Dec 19, 2002
    149
    I just moved and I need to remove a port from my SVS subwoofer. The only problem is that I can't lift it off. Can anyone give me some tips- besides steroids [​IMG] Thanks in advance
  2. TimJC
    TimJC Stunt Coordinator
    Sep 22, 2005
    62
    Just give the cylinder a bear hug and pry the outer vertical edge of the metal ring around the outside of the grill upward with your fingertips. That metal ring is part of the grill. It helps to work a little bit at a time at various places around the perimeter at first. It'll make sense once you do it once.
    Tim
    [​IMG]
  3. Josh Wolfman
    Dec 19, 2002
    149
    I tried the bear hug thing for 1/2 hour. It did not work. I eventually used a screwdriver. It was stuck or something. Got the tune out and all is good. Thanks for the reply.
  4. dany
    dany Supporting Actor
    Jan 4, 2005
    694
    You could always e-mail SVS and ask them,they did make it.
  5. chuckg
    chuckg Supporting Actor
    Apr 27, 2004
    917
    Get a bunch of nice, ripe bananas, and wave them in front of his face. Be calm, and make no sudden movements.
    What? oh -- sorry, I thought you said "gorilla." Never mind.
