How do i get into the Bios? (NT)
Discussion in 'Archived Threads 2001-2004' started by AaronMg, Jan 29, 2003.
  1. AaronMg
    AaronMg Stunt Coordinator
    Mar 20, 2002
    247
    How do I open up the Bios.
  2. John*Jones
    John*Jones Stunt Coordinator
    Jun 4, 2002
    189
    to get into the bios you normally have to press f2 or the delete key right after you boot up or restart your pc.
  3. AaronMg
    Mar 20, 2002
    247
  4. MikeyWeitz
    MikeyWeitz Supporting Actor
    Feb 10, 2002
    939
    Depends on which bios and computer manufacturer u have.
    OS does not matter.
    Got to your computer makers website and do a search. It can be either f2, delete, f10, conrtl-f1 and I have even seen old Dell optiplex's use cntrl-alt-del
  5. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    It should tell you which key(s) to press. It's usually worded as "Press XX to enter setup" or something along those lines.
  6. Scott L
    Scott L Producer
    Feb 29, 2000
    4,457
    Now don't get go crazy in the bios on your first try! [​IMG] Turning off your COM and serial ports is a simple first tweak, if you don't use them of course.
