How do I do a product compare at bestbuy.com?
Discussion in 'Archived Threads 2001-2004' started by DanMU, Dec 30, 2002.
  1. DanMU
    DanMU Agent
    Dec 28, 2002
    40
    I've seen a couple of links in threads in this forum that are at Bestbuy.com and have a side by side comparison of AV receivers. Great feature and I want to know how to do that. Poking around bestbuy.com I can't find a way to access this feature. Thanks for help!
  2. Jeffrey D Smith
    Jeffrey D Smith Stunt Coordinator
    Feb 19, 2002
    98
    When browsing a list of components (Exp. receivers) there is a box next to each one. Check the boxes of the units you want to compare. At the top and bottom there is a button that says something to the effect of "Click here to compare."
    Crutchfield.com also has this, and is much more accurate then BestBuys site.
  3. DanMU
    DanMU Agent
    Dec 28, 2002
    40
    To enable the feature you have to register. Then it's there. I did register and got the feature. I'll be sure to check out Crutchfield. Thanks!
