How do I completely uninstall everything "nvidia" from my cpu?
Discussion in 'Archived Threads 2001-2004' started by Rob Varto, Mar 26, 2002.
  1. Rob Varto
    Rob Varto Supporting Actor
    Mar 5, 2000
    711
    I decided to forego the GeForce4 and picked up an ATI Radeon 8500 retail today. Im concerned that my Soyo Dragon+ may have some compatibility issues with a whole new video card (currently a Leadtek GeForce2 GTS 32MB) unless I completely uninstall all the Nvidia reference drivers. How do I go about doing this without reformatting?
    I've got too good of a High Heat Baseball season going to lose it all with a reformat! [​IMG]
  2. Matt Stryker
    Matt Stryker Screenwriter
    Oct 12, 2000
    1,307
    Rob- I'd try simply uninstalling from Add/Remove Programs and then use a registry cleaner (like Norton's RegClean) to get rid of all the keys. The actual driver files on your system should only cause a problem if they are in use by Windows at the time.
    You might also try to simply find the High Heat savefiles and reformat. Reformatting a PC (unless you are running a unix based OS) periodically is a really good idea.
  3. David_Stein
    David_Stein Second Unit
    Feb 13, 2002
    422
    well, the standard way to change video cards is to switch to standard VGA drivers, then install the new card with the standard VGA drivers and install the new ati drivers when it prompts you. if there were extra programs that you installed from nvidia just use the add/remove programs
    as far as i know, a registry cleaning isnt necessary, but it can only help...
  4. Wes T
    Wes T Stunt Coordinator
    Apr 11, 2000
    55
    Hello again Rob. Go to www.guru3d.com and download the program called Detonator destroyer. It will clean all registry settings out. You should first do an uninstall, then run the destroyer. Restart and just install a standard VGA adapter. Restart again and then install the new drivers. Should fix you right up. Wes
  5. Rob Varto
    Mar 5, 2000
    711
    Thanks guys! Things are workign great! Too bad Im stuck trying to get another damn computer built and not gaming with my new vid card [​IMG]
  6. JasenP
    JasenP Screenwriter
    Dec 21, 1999
    1,280
    110
    Kalamazoo, MI
    Jasen
    Rob
    FYI: ATI just posted a new MMC, Hydravision, and Display drivers on their site. Make sure when you do install your Radeon 8500 you use these instead of the crap on the install disc.
