EricHaas
- Dec 25, 2001
Dumb question. I just purchased 250' of 10 gauge oxygen free at an extremely cheap bulk rate. I have Paradigm Studio front speakers, with 2 sets of binding posts for bi-wiring. I am not sure I believe in the benefits of bi-wiring but I see no reason not to since I have way more wire than I need. Anyway, my question is how to do it. I assume I take 2 runs of cable and bind them together with electrical tape. Then I terminate them at the speaker end with either spades or banana plugs, and attach the 2 conductors from one cable to the upper binding posts and 2 from the other cable to the lower binding post. I presume these correspond to upper and lower frequencies. OK, so what then do I do at the amp end, since there is only one set of posts for each speaker? Do I try to terminate the 2 cables together?
