How do I access service mode on my Sony WEGA? (1 Viewer)
Mike DB
I just got a Sony WEGA 27FS120. I got it because I like having the 16x9 mode. The picture is OK but it could be a lot better with some tweeking beyond the regular adjustments. ( I know how to tweek certain advanced service controls but on my last set they were just rotary pots inside the set on the cirsuit boards, now you access these controls via a remote code) I just need to get into the service menu to fine tune it a bit.
Does anyone know the code on the remote to access the service menu on this model? Or can you tell me where I can find out?
matt mettin
Display, 5, Vol+, Power, Menu (on the OEM remote)
That should get you into the service mode. If it doesn't let me know
Matt
:D
Aaron_Mum
This site will help you get your settings in the ballpark.
Don't foget to correct the oversqueeze in 16x9 mode - its nasty from the factory. Here is a link for fixing that.
andriesprice
