How did you tweak your X1???
Discussion in 'Displays' started by Joe Zemaitis, Mar 21, 2004.
  1. Joe Zemaitis
    Joe Zemaitis Stunt Coordinator
    Feb 24, 2004
    53
    I'm interested in getting everything out of my X1. I'd like to know what settings did you have to change to get the picture its very best for everyone reading this. I'm pretty much running out of the box settings, and I think it still looks a little blurry especially with DVD's... Its weird. Cable, it looks fine, of if I plug my laptop into it, then run a dvd, then it looks fine.
    Basically looking for any info on making it look its very best.... Any setting changed out of the box! Thanks
    Joe
  2. ChrisWiggles
    ChrisWiggles Producer
    Aug 19, 2002
    4,791
    You should calibrate with a proper test disc, and you should try to bypass internal scaling by using the native panel resolution on your computer. This will provide the best source for it, and bypass the internal scaling which is not as good.
  3. Joe Zemaitis
    Feb 24, 2004
    53
    OK... I'm new to this... Can you put that in terms I could better understand? Where do I get a calibration disc? Also, I never hook up my computer other then when i was troubleshooting.
    Joe
  4. ChrisWiggles
    Aug 19, 2002
    4,791
    Avia or DVE. See the beginner's primer and FAQ (in the basics forum, theres a link at the top) for some more info.
    Computers are some of the best sources for HT use, and can be especially helpful for digital projectors too. This is because a digital projector has a native, fixed panel resolution. Every resolution that it accepts, it scales to that resolution, because that is how many pixel elements it has. By feeding it *exactly* the native panel resolution, you bypass this low-quality processing. High-quality video scaling/processing, however, is very expensive, and processor intensive. Scalers built-in to most digital projectors are of low quality. Stand-alone consumer and professional grade video processing equipment alone would cost many magnitudes more than your x1 costs. However, a computer does the same thing, and if you already have a computer, then it's free, except for time and some software [​IMG]. Anyway, if you're interested in this aspect, learn about HTPCs, that's where it's at.
    Until then, start by properly calibrating with Avia or DVE, and view in a proper, darkened environment.
  5. Joseph Bolus
    Joseph Bolus Cinematographer
    Feb 4, 1999
    2,524
    246
    4,110
    There's absolutely *NO WAY* that DVD's should look worse than cable on your X1!!
    Please make sure that:
    * You have the X1 running in either its "Film" or "Video" preset mode. Running in "Presentation" mode will "crush" the whites which will result in the loss of some detail.
    * Make sure that your DVD player is set up for a 16:9 Widescreen monitor. (You can adjust this via the SETUP MENU on your DVD player. Once the DVD player is set to 16:9 there is never a need to adjust this setting again. If the DVD that's playing is not anamorphic, the player will automatically revert back to 4:3 mode.)
    * When playing anamorphic DVD's on the X1 always switch the aspect ratio of the X1 to 16:9. (You can actually leave the X1 configured for a 16:9 screen area and then utilize the "Native" aspect ratio for 4:3 material, if you desire.)
    The display of anamorphic DVD from almost any standard DVD player on the X1 should be "razor sharp" after adhering to these simple rules.
    EDIT: If your DVD player is not progressive scan, than at least run it into the s-video input of the projector. The X1's excellent Faroudja DCDi circuit will take it from there.
  6. Joe Zemaitis
    Feb 24, 2004
    53
    I ended up changing the sharpness to the sharpest setting. Thats what I had the component set to. The S video was only sent to standard. Is it just me, or does the picture look much brighter when my laptop is plugged into the svga port? I have an old school DVD player from like 99... Its a Phillips DVD 825... I don't know if the available adaptors would work for my projector.
    Joe
  7. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Wow the sharpest? Is that for DVD, cable, or both?
    With AVIA, i found the sharpest to be WAY too sharp, halos everywhere... I have it set on softer, or standard...
    Cable or satellite will be blurry and soft ususally, but helps by watching it in NATIVE rather than 4:3.
    How do you have the DVD hooked up? Are you sure its focused as best possible? I have my X1 hooked up to a 6 yr old Toshiba SD2109 via Svideo, and with good DVDs it looks great (i was amazed at how great it looked watching LOTR:TTT).
    What movies did you find were blurry? Could be the DVD...
  8. arman-m
    arman-m Auditioning
    Mar 5, 2004
    6
    it could be dvd the dvd.....
    concert,documentary and tv series dvds usually look blurry or grainy....
    I was really suprised when i first put my elton john gratest hits music dvd. it's almost unwatchable, colors were terrible.... also FRIENDS dvds look little blurry .....
    but movies look great on x1 so far.
  9. Joe Zemaitis
    Feb 24, 2004
    53
    I have mine set to native. I sure hope its the right setting since its already mounted on the ceiling! Anyways, I was noticing it on Mona Lisa Smiles just two nights ago. I kept rubbing my eyes because they were getting tired. Hm... The only other setting I have changed is the keystone to about 60%, the ceiling setting so the picture is upside down, overscan is turned on, and the brightness is at 60.
    Joe
  10. Joe Zemaitis
    Feb 24, 2004
    53
    "EDIT: If your DVD player is not progressive scan,"
    Is my Panasonic DVD-825 progressive scan? I know it doens't have composite outputs.
    Joe
  11. Joseph Bolus
    Feb 4, 1999
    2,524
    246
    4,110
    I'm not real sure. I do know that a few of the older players had component outputs, but were *not* progressive scan. Since the X1's Faroudja DCDi circuitry would not "kick in" for a component signal, this could well be the main source of your problem. Try running s-video, which will allow the X1 to de-interlace the signal with its Faroudja chip. The difference could be dramatic.
  12. Sheldon-m
    Sheldon-m Stunt Coordinator
    Oct 22, 2003
    217
    On my X1 I have no problem with dvds. they look very good.(even though that a have it projecting on the wall)
    One complaint I have is with dish network connection. the boxes that dishnetwork gives are sorry. i have it hooked up with s-vid. i mean it looks like the box can't convert the image. it is jagged. it has artifacts. They say thats how digital image is suppose to look. dark scenes and scenes with smoke look very jagged. it is very disapointing. has anybody else had this problem.
  13. Dave Man
    Dave Man Stunt Coordinator
    Oct 30, 2003
    85
    Would it be better for him to go from component to the VESA port or component to S-Video?
    David
  14. Joseph Bolus
    Feb 4, 1999
    2,524
    246
    4,110
    Assuming that part of his problem is due to the fact that he owns a player with component outputs, but which is *not* progressive scan (and there were early DVD players built like this, although I have no idea if his is in this category), then he would be best going s-video to s-video. (He said his DVD player doesn't have composite outputs; I assume it *does* have a s-video output.)
  15. Joseph Bolus
    Feb 4, 1999
    2,524
    246
    4,110
    There's a lot of compression going on with the dish network and this *will* lead to "jaggies." And when those "jaggies" are blown up to 96" or so they can really be distracting. There's only so much that the X1's Faroudja's chip can do with this kind of material. In order to help out with this on my system, I do the following:
    1. Run all Dish and/or Cable signals in the X1's "Native" mode. This results in a smaller 4:3 picture which will help out with at least some of the artifacts.
    2. Experiment with running "Brightness" slightly higher than "Contrast" for just this one source. (Say, 65 for "Brightness" and 55 for "Contrast".) I've found that this can also help mask some of the artifacts. (Bulb life, by the way, is not affected by the "Brightness" and "Contrast" settings.)
    3. Set the "Sharpness" setting to "softer" for this source.
    That's about it! Don't forget that you can save and restore User Presets for various sources.
    EDIT: I've also found that for dish/cable sources, it sometimes helps to "pump" a little more life into the colors. You can do this by going to the "Advanced Color Control" and setting the Red, Green, and Blue gain settings to 75 or higher. Again, this will not affect your bulb life.
