How can I make my remote work through a cabinet??
Discussion in 'Archived Threads 2001-2004' started by Michael P, Apr 12, 2002.
  1. Michael P
    Michael P Agent
    Mar 2, 1999
    26
    Hello, I recently put my receiver in a stereo cabinet and want to find a way to make the remote work with the cabinet door shut. I have the oem remote and a pronto. Are there any inexpensive ways to do this, without leaving the door open[​IMG]
    Thanks Mike
  2. Daren Welsh
    Daren Welsh Supporting Actor
    Jan 16, 2002
    660
    My Mits came with IR repeaters. You plug them into the back of the TV and then put the emitters in your cabinet facing the IR recievers of your equipment. Then point the remote at the TV and voila, the signal is forwarded to the hidden equipment. I've never used these, though, and I don't know where you can get them elsewhere. Would X-10 or remotecentral.com have something like this?
  3. James Mudler
    James Mudler Stunt Coordinator
    Feb 1, 2001
    207
  4. Ralph Summa
    Ralph Summa Supporting Actor
    Nov 6, 2001
    715
    This is what I use. Cheap and gets the job done. I have a dual IR repeater that came with my TV which I plugged into a 1/8" mic jack in the back of the hidden pyramid and it contols everything. Not bad for $50. You can buy the repeaters or additional receivers too.
    Ralph
  5. Troy Swope
    Troy Swope Stunt Coordinator
    Mar 1, 2002
    50
    I use the exact system Ralph mentions above. My system works great, i can control all of my devices that are mounted in a hallway closet from my hometheater in the other room. works great!!
  6. Daniel Swartz
    Daniel Swartz Second Unit
    Mar 3, 2002
    448
    Ralph and Troy: Do those Radioshack receivers operate on the 2.4GHz band? 900Mhz? Other? Thanks.
  7. Bill_Weinreich
    Bill_Weinreich Second Unit
    Sep 25, 2000
    317
    Daniel,
    It works on about 418 MHz. Specs arehere
    Bill
  8. Daniel Swartz
    Mar 3, 2002
    448
    Thanks Bill!
  9. Selden Ball
    Selden Ball Second Unit
    Mar 1, 2001
    412
    Selden
    In Michael's original post, he mentioned running his system with the doors shut. I hope allowance has been made to provide plenty of air flow. A/V equipment can generate a lot of heat. When you overheat electronics, it tends to develop intermittant problems and have a shorter lifetime. Many receivers include an over-temperature shutdown. Losing the image and sound in the middle of a movie can be, shall we say, inconvenient.
  10. Ralph Summa
    Nov 6, 2001
    715
    I will second what Selden says about ventilation. I have fans running off the switched outlet in the back of my Yamaha receiver. The fans work wonders when the equipment is on, but my Hughes HD STB generates heat even with the power off, so I'm looking at plug-in thermostats that will kick the fans on when the cabinet starts to warm up. I thought about running the fans 24/7 but they'd burn out in a little over a year!
