How can I hook up both DVD-A and SACD with one set of 5.1 inputs? (1 Viewer)
I realize this question was asked in an old thread, but when I tried to "post reply" to it, it wouldn't allow me to.
I was just wondering if there were any new solutions to this problem? I just ordered the Sony SCD-C555ES player and I'm using my Panasonic RP91 for DVD-Audio.
Also, I heard that it is better to use the analog RCA outputs from this player than the digital? My receiver is the Yamaha 995 if that helps.
KeithH
Adam, Radio Shack makes an A/V switch box for $15, and with two of these, you can switch between multi-channel DVD-Audio and SACD sources. I use them and detect no signal degradation. The Radio Shack part number is 15-1952. Search this board for '15-1952' for more on how these switch boxes are used.
ofyclinic
