How can I get an extra USB "header" inside my case?
Discussion in 'Computers' started by Jonathan Burk, May 8, 2006.
  1. Jonathan Burk
    Jonathan Burk Second Unit
    May 31, 1999
    452
    5
    110
    Castaic, CA
    Jonathan Burk
    I'm trying to hook up a card reader, and its only connection is an internal "header" plug. Well, my motherboard doesn't have a USB header, so I need to find another solution.
    I figure I have two options:
    1. Cut off the existing connector and splice in a conventional USB plug, and snake it out to the back of the case (or find a pre-built adapter).
    2. Find a USB card that has a USB pins on the inside. Does anyone know if these exist?
  2. Mike LS
    Mike LS Supporting Actor
    Jun 29, 2000
    838
    I've gone the first route before, though my card reader came with an adapter.
    See if the following would work....
    http://www.performance-pcs.com/catal...oducts_id=1116
    As for option 2, I've not seen USB card with header pins on it, but they very well may exist.
  3. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    How about...
    3. Find another card reader that uses a USB plug.
    Glenn
  4. ClintS
    ClintS Stunt Coordinator
    Nov 26, 2003
    169
