How can I fix a drooping headliner in our old car?
Discussion in 'Archived Threads 2001-2004' started by Wade, Sep 26, 2002.
  1. Wade
    Wade Stunt Coordinator
    Jun 30, 1997
    147
    You can't even see the top of the passengers head because it droops so much. You cant even roll down the passenger window because it's ripped along the edge thus allowing the wind to further the damage. I was thinking about ripping it out but then I thought a spray adhesive might do the trick. The only thing about the spray adhesive is it may be to thin and run through the fabric.
    Any quick and cheap ideas?
    Wade
  2. Eric Kahn
    Eric Kahn Guest
    You did not say what kind of car
    spray adhesive will only be a short term fix, most headliners "droop" because they were originaly fixed to a backing with a thin layer of foam rubber and it is the foam rubber breaking down that cause's the cloth to fall, the spray adhesive will just pull down more foam rubber
    some times you can staple the headliner back up but this has become such a common probelm that you might be able to get it replaced for about 100 dollars epending on the car
  3. Wade
    Jun 30, 1997
    147
    Eric,
    The car is an '89 Plymouth Sundance. Other than the headliner the interior is in pretty good shape. I'll look to see if I can staple it.
    Wade
  4. Chad Ellinger
    Chad Ellinger Second Unit
    Jun 18, 2000
    269
    You can get a headliner repair kit at Salvo, Autozone, TrakAuto or some other auto parts store. They run about $30 + the cost of adhesive spray. Worked *reasonably* well in my car, much better than staples.
  5. JasenP
    JasenP Screenwriter
    Dec 21, 1999
    1,280
    Kalamazoo, MI
    Jasen
    I used two-sided foam tape in my old Escort. Make sure to vacuum out the disintegrated foam or it may come back to haunt you.
  6. Chris Smith
    Chris Smith Stunt Coordinator
    Feb 14, 2000
    118
    In my old car I used thumbtacks. Then my friends started making a game out of re-aranging the thumbtacks to make images words or phrases. It was a good time.
  7. Bill_D
    Bill_D Supporting Actor
    Dec 10, 2001
    755
    I had a '72 Buick Electra 225 in High School a while back and my headliner was loose as well. I didn't even think about fixing it until an Atlanta cop pulled me over and told me that my "fabric was flapping", "see about getting that fixed." Used some 2-sided tape that worked for 3 months at a time or until it rained. Kept a fresh roll in the trunk.
  8. brentl
    brentl Cinematographer
    May 7, 1999
    2,921
    110
    Pop rivet[​IMG]
    Brent
  9. Bill_Weinreich
    Bill_Weinreich Second Unit
    Sep 25, 2000
    317
    If you plan on replaceing the headliner, the DIY route will run you about $50 and an afternoon's time. Use the 3m adhesive #08088. If you plan on a professional, check around but it will probably run you about $150. If you just want it out of the way, most auto supply houses have screw in tacks just for that purpose (check the HELP! section)
    Bill
