How can I do this?
Discussion in 'Archived Threads 2001-2004' started by TreyP, Feb 11, 2002.
  1. TreyP
    TreyP Stunt Coordinator
    Oct 3, 2001
    122
    My TV has only one set of component inputs. If I have to things that I want to use with component video (dvd & XBox), is there a way to get both of them on there without having to switch them out?
  2. Neil Joseph
    Neil Joseph Lead Actor
    Jan 16, 1998
    8,332
    Neil Joseph
    What you need is a component video switcher. I am assuming your receiver does not have this ability (only higher end units have this) but there are commercial products available out there that can do this.
    Anyone know a specific comp video switcher out there??
  3. Glenn Overholt
    Glenn Overholt Producer
    Mar 24, 1999
    4,203
    You don't need a component switcher to accomplish that. Just an ordinary A/V switcher (red, white, yellow) will work. They start just over ten bucks.
    Glenn
  4. Scott_G
    Scott_G Second Unit
    Jun 18, 2000
    268
  5. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    Radio shack sells a simple A/V switcher that will work for your setup. Although it will degrade the signal slightly, you won't notice it because your TV (like all TVs) can't handle the full HD bandwidth. Your other (more expensive) solution would be to get a receiver with component video switching...
