How can I determine a speaker's impedence (ohms)?
Discussion in 'Archived Threads 2001-2004' started by Ed O, Nov 27, 2001.
  1. Ed O
    Ed O Agent
    Sep 25, 2000
    36
    Will a reading from an Ohm meter work? If not, how can I determine this info? The spec label is missing from the speaker in question.
    Thank you.
  2. Andy_S
    Andy_S Second Unit
    Jul 19, 2000
    393
    No, an ohm reader won't work. The impedence of a speaker is not the same as a resistor. I'm not sure exactly how it's measured, but I believe it's some sort of average. The higher the frequency passed through a coiled wire, the higher the impedence. Since an ohm meter measures resistance by passing a flat DC current through the leads, it would read almost 0 impedence*.
    *note: This is very basic electronics so I'm sure I'm not 100% correct on this.
  3. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
  4. PatrickM
    PatrickM Screenwriter
    Aug 10, 2000
    1,138
    You'll need something like an audio analyzer or a audio frequency network analyzer in order to read the impedance of a speaker.
    Patrick
  5. jeff lam
    jeff lam Screenwriter
    Jun 4, 2001
    1,798
    San Jose, CA
    Jeff Lam
    Are you talking about a speaker system(mid/tweet/x-over) or just a single driver?
    From my experiences and experiments if you use a ohm meter for a single driver, you will get the DC resistance. I usually found 4ohm speakers to have a 3.4 - 3.8 ohm DC resistance. If you want to measure a speaker system, the meter won't show anything.
  6. Norm Strong
    Norm Strong Stunt Coordinator
    May 7, 1999
    142
    Yes, you can use an ohmmeter. The DC resistance of a speaker is usually around 80% of the minimum AC impedance.
  7. Danny Owens
    Danny Owens Agent
    May 30, 2000
    48
    IT depends how accurate you want to be and what information that you want to gain from the measurements. To do it properly for the entire spectrum, you would need a volt meter, ammeter, and some type of tone generator. Since a passive crossover is somewhat of an unpredictable dynamic load, it is hard to determine impedence without factoring in reactance.
    What I have done is place a volt meter across the load and an ac ammeter designed to be in series with the load. An amprobe is not accurate enough since the amprobe is a current transformer with on hell of an inductive lag. With a constant volume, source a signal of known frequency to the amp. At the speaker, measure the voltage and the current.
    Divide the voltage by the current and that gives you the impedence of the speaker at that frequency. If you have gone that far, you may want to go ahead and plot the impedence for the entire spectrum based on ISO centers.
    Like anything else in the audio industry, speaker impedence ratings are not standardized. Some manufacturers rate "nominal" which simply means average; but, they dont tell you at what points in the spectrum the measurements are taken to come up with an average. Other speakers are impedence rated at a given frequency; typically 1khz.
    Danny
  8. Ariel
    Ariel Stunt Coordinator
    May 13, 2001
    109
    it is not possible to measure the impedance of the speaker using conventional equipments. it is the summation of the resistive, capacitive and inductive reactance on a given frequency. to find out this info, try to contact the speaker manufacturer. some manufacturers have this information and some reviewers also post this info on their equipment reviews.
