Joe Szott
- Feb 22, 2002
- Joe S.
I'm waiting for the DVD-R drives to go on fire sale again, then I'm buying a nice new Dell to stretch it's legs out on Half Life 2
Don't companies that put together custom PC's from parts for you charge a whole lot more to start with? I'm talking companies like alienware.Dunno about Alienware specifically, but those boutique companies use high-end components (not the cheapest ones). I've even seen some of them offer overclocked video cards, fully tested and guaranteed, not something you'd find normally. They may also have custom cases, some of them really nice and/or extravagant. The system is very neat; everything is bundled and tied. The OS may be tweaked for speed; something you could do yourself in five or ten minutes if you knew where everything was, but the point is they do it for you. And for all that, yes, they charge a heck of premium. Whether it's worth it is an individual choice.
Dell is not your regular beige box assemler. They have custom hinged cases and power supplies, and processor shrouds with heatsinks instead of fans. But as mentioned, their service is lacking. Based on a recent experience, I would advise that:
If the unit arrives damaged and you call to exchange it, do not let the customer service rep transfer you to tech support. Tech support will try to fix it, or send someone to service it. You might try stressing the word "exchange", or ask to be transferred to someone that actually knows the company policy, which allows a front-line rep to make a straight exchange. Note that although their service opens at 7am Central, their "escalated" Resolution department doesn't open until 8.
Should the replacement unit arrive without the return label, when you call customer service (again) to arrange pickup, do not let the rep use the automated request system, which occasionally "doesn't work". Insist that the rep call Airborne and get the confirmation and airbill number.
//Ken
No reason to do anything else as far as I can see.
I worked in a Dell shop, and many of the machines had integrated video (which is why some of the fellows were issued clones as a perk).
Another minus was that they tended to be non-upgradeable, which meant rebuying the whole box when the CPU became obsolete.
RD
When you compare this 250w rating to others, often, you're talking an output closer to 340w supplies.Kinda stretching it..
My 300 watt Fortron (which is just a rebranded Sparkle) actually has 200 watts on the +3.3v & +5v rails. Same with the Sparkle I looked at. I know 170 is surely ok for a basic system (also the very minimum of what's recommended), which is why I said if you plan to do some major upgrading the PSU might give some problems.
Unfortunately PC Power & Cooling and Enermax just ain't what they used to be (I have had both). Antec however is still on the ball, the only 300 watt PSU I see from them on Newegg supplies 220w on those rails.
