How bout an HK AVR 120 for a JBL setup on a budget ... thoughts?
Discussion in 'Archived Threads 2001-2004' started by Jason Hammerly, Sep 24, 2002.
  1. Jason Hammerly
    Jason Hammerly Supporting Actor
    Oct 28, 1999
    739
    I was considering upgrading to the AVR 120 and am wondering if anyone hs any experience with it with JBL speakers. Specifically I'll be running N38's for the mains and the N-cneter (both 90db efficiency) and N24's as surrounds. What do you think? I'm upgrading so I can get DPL 2 and am trying to keep the upgrade under $250 and still get a quality unit. I don't care about the lack of preamp outputs and OSD. Thanks.
  2. Jason Hammerly
    Oct 28, 1999
    739
    anyone?
  3. KyleGS
    KyleGS Second Unit
    Feb 12, 2002
    342
    I just set my mom up with the HK125 and the NSP1 set (N24's) all around. It sounds absolutely amazing for the price. I can't believe the entry level HK sounds so good. I can't imagine the 520. I really like that receiver. Her set-up sounds better than my HT setup and I am running the S38's and S-center BUT with a DE Sony 5.1 receiver. So that just tells you what a difference the receiver makes! I so go for it- no doubt- but maybe you should hunt for the newer 125...? G'luck
  4. Jason Hammerly
    Oct 28, 1999
    739
    I'm kind of thinking about the 320, but it is twice the price. Still, $400 for the 320 would be pretty fair it seems for the upgradeability it would give me. I just don't know.
  5. Joe Szott
    Joe Szott Screenwriter
    Feb 22, 2002
    1,962
    Jason,
    To stretch your harmon kardon dollar, the refurb part of their store is a good place to check:
    http://www.harmanaudio.com/
    Save some money and still get the full warranty.
