How big of a difference...
Discussion in 'Archived Threads 2001-2004' started by Jason Koz, Aug 6, 2002.
  1. Jason Koz
    Jason Koz Extra
    Jul 25, 2002
    15
    How big of a difference in picture quality is there between a 32" HD and 32" analog set (both flat-screens) on DVDs? I realize that the HDTV is better, but how noticeable is it on a screen of that size? I'm having trouble justifying the extra $400.
    I'll be sitting ~8 feet away from the screen if that helps.
    Thanks.
  2. Gregg Loewen
    Gregg Loewen Video Standards Instructor, THX Ltd.
    Insider
    Nov 9, 1999
    6,374
    32
    6,610
    New England
    Gregg Loewen
    Huge
  3. Drew Eckhardt
    Drew Eckhardt Stunt Coordinator
    May 10, 2001
    246
    Interlacing artifacts are still noticeable at 8' on a 32" set, as are down-conversion artifacts playing anamorphic DVDs without anamorphic squeeze.
    Beyond that, it's a subjective question. You need to plug an appropriate DVD player into the sets in question and see for your self.
  4. Jack Briggs
    Jun 3, 1999
    16,738
    129
    I would echo Mr. Loewen's response. There's no comparison. It's that big a deal.
  5. Mike I
    Mike I Supporting Actor
    Jan 20, 2000
    720
    Pay the extra 400..Not only is the difference in picture quality dramatic, analog tv's are an antiquated technology..It is looking more and more likely, Congress and the FCC is going to force the 2006 analog shut down to happen on time..
  6. Brent Hutto
    Brent Hutto Supporting Actor
    Aug 30, 2001
    532
    To my eye, shopping for TV's at Circuit City and Best Buy, you really need a line-doubled (i.e., Digital/HD-Ready) set in those sizes at that distance. At my usual viewing distance of seven feet, the 32" analog sets had unacceptable scan lines and the 36" ones were unviewable. I don't think it would be much different at eight feet.
    I will say that on certain anamorphic DVD's, an analog Wega that's doing the squeeze can be close acceptable at eight to ten feet. But even then on large areas of white in the picture the scan lines are right there to see.
    But you don't really need my opinion. Just go to any store that has a 32" analog Wega and a 32" HDTV-ready Wega near each other and watch the same material on both from eight feet away. And if you use a 36" it will be much, much worse.
  7. Warner
    Warner Agent
    Jul 25, 2002
    38
    Why are the scan lines less visible on an analog set that does the squeeze?
  8. Drew Eckhardt
    May 10, 2001
    246
