How big is too big and questions on speaker stands?
Discussion in 'Beginners, General Questions' started by Christopher_P, Oct 7, 2003.
  1. Christopher_P
    Christopher_P Stunt Coordinator
    Jul 8, 2002
    108
    Posted before on questions about what I'd want in a TV and a HTIAB and now I have a question on room placement and speaker stands [​IMG]
    Our room is 20x20 and we will be sitting 11 feet from the TV. How big is too big for this room? I already have a onkyo HTIAB, philips dvd player, consoles, etc.. Also I figured out around what I want in a tv (HDTV wide screen plugs etc..) but now I need to figure out what size is a good size for this room. Bigger is better RAWR but seriously whats a good guide to go on for TV size?
    I also need some help on speaker placement and what sort of speaker stands I will need for my front 2 speakers and back 2. (figure the center speaker will go on top of the TV. But the front speakers are much heavier than the back 2 so I can either have them up on top of our media stands which will place them several feet above ear level and several feet above the rear speakers or I can find some sort of speaker stand to hold them up on the sides of the TV)
    I also have one other problem. Our living room opens up into a tiled kitchen and a carpeted den(living room also has carpet) and this room also has a very large window (double the size of a normal window). Trying to figure out should I look into getting some custom blinds made? (My father and uncle put this window in a long time ago and the size and glass was from another building and its not a "standard" size so I would have to find some way to get custom sized blinds)
    Anyway thanks ahead of time for the replys and I hope to post here more often always great info here for us HT newbies. (Feel like I'm learning basic PC hardware all over again eek!) [​IMG]
  2. Geno
    Geno Supporting Actor
    Oct 1, 2001
    637
    whats a good guide to go on for TV size? ---budjet [​IMG]
    I sit about 14 feet from my 120" diagonal screen. it isnt overwhelming ...yet.
    A friend of mine has a 63" widescreen and he sits 9 feet away from his TV.
  3. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    This Viewing Distance Calculator can give you some help.
    For an 11' distance you would need a 98" diagonal screen to hit the THX recommended size.
    You should sit closer and get any of the popular sizes.
