How Big can you go (screen size)?
Discussion in 'Displays' started by ShawnN, Sep 8, 2003.
  1. ShawnN
    ShawnN Auditioning
    Sep 5, 2003
    5
    How big a screen would or should one get in a 9'x 17' room? Is there a formula for that sort of thing?
    Thanks[​IMG]
  2. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    THX recommends a 36° viewing angle.
    For example, if you sat 7' away from your screen, to meet Lucas' standards, you'd need around a 60" 16:9 TV.
    HERE is an online calculator that breaks it down into greater detail.
  3. Jeff Engel
    Jeff Engel Stunt Coordinator
    Feb 13, 2002
    205
    And remeber that THX recommends 36 degrees for the LAST row of seating, not the primary, so your furthest row back should have 36 degrees.
  4. Stephen Tu
    Stephen Tu Screenwriter
    Apr 26, 1999
    1,573
    Those THX recommendations are for movie theaters, where with film's greater resolution you can have a much bigger screen. At home with mixed sources at much lower resolution you aren't going to get very good picture quality at those distances.
    At 7' a 60" would look pretty bad with typical SD sources.
    Anyway, people's tastes vary, the only foolproof way is to go to the store with a tape measure and see for yourself what you like, on a variety of sources. But I would start with a 16:9 set with diagonal approximately half of your viewing distance, and try bigger/smaller from there.
  5. Andrew Bunk
    Andrew Bunk Screenwriter
    Nov 2, 2001
    1,825
    I was at 8' with my new 57", and it seemed too close. I moved back to about 9', and it's much more comfortable to view from that distance.
  6. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    RPTV or Projector????
  7. Ron-P
    Ron-P Producer
    Jul 25, 2000
    6,284
    5
    Ron
    My 9'x16' room has an 80" screen with seating at 9' and 12'.
    Peace Out~[​IMG]
  8. ShawnN
    ShawnN Auditioning
    Sep 5, 2003
    5
    Hi I will go with a projector.
  9. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    How high is your ceiling? Probably 80" * 45" with that wide of a wall...
