How big a TV do you need to really notice the Anamorphic enhancement?
Discussion in 'Archived Threads 2001-2004' started by Paul_D, Sep 9, 2001.
  1. Paul_D
    Paul_D Cinematographer
    Jul 28, 2001
    2,048
    My 25" 4:3 TV can perform the anamorphic squeeze, and although I can notice a slight improvement (the scan lines disappear), I wouldn't say the improvement enhances the experience for me. Hoiw big a TV do you need for it to make a BIG difference.
    My main TV is 42" 4:3, but it can't perform the anamorphic squeeze, so I can't test it on that size.
  2. gregstaten
    gregstaten Supporting Actor
    Aug 1, 1997
    608
    3
    110
    This isn't a simple question to answer as there are a lot of variables.
    First off, if you have a 16x9 set, then the benefit is apparent regardless of size. For example, I can certainly tell the difference on my portable player and I can also tell the difference on the 19" 16x9 pro monitor at work.
    It also depends upon the quality of the set. Again, at work I have a Sony 13" PVM 4x3 monitor. When I switch to 16x9 the difference is readily apparent. But I've also seen sets that can't really resolve the differences. For example, when I visited my father a few years ago, I remember noting that their living room set couldn't resolve much beyond VHS resolution (literally).
    Finally, you have to look at the quality of the downsampler in your DVD player. If the downsampler is adding artifacts to the downsampled image then the difference between 4x3 letterbox and 16x9 true will be more apparent.
    So, this comes down to the classic "your mileage may vary."
    -greg
  3. Joe D
    Joe D Supporting Actor
    May 21, 1999
    838
    I have a 25" TV and a year ago I was tweaking with my TV, I did the squeeze trick on it and I must say I was pretty underwhelmed. I guess after a few movies I noticed the colors on movies were a lot better. Then, I noticed the image was more 3-Dimensional. Say I've been using the squeeze trick for a year now and I attemped to watch The Insider without the trick, the image lacked the life that the 16x9 version had.
    So, with a 25" there's a difference, but it's not apparent right away.
    Joe Dahlen
    "Take hold of the flame, you've got nothing to lose, but everything to gain."
  4. Matt Stone
    Matt Stone Lead Actor
    Jun 21, 2000
    9,063
    Hmmm...I can notice great improvement on my 27" Wega...so maybe it is the TV. And are you preforming a hacked-ass, bust into the service menu trick, or does your TV have native functionality for Anamorphic Squeeze. I only ask, becuase when I used to perform the "trick" on my old 27" Mits, I noticed little to no difference, and sometimes the picture looked worse...but with the feature on the Wega it looks great.
  5. Steve Felix
    Steve Felix Supporting Actor
    Jan 17, 2001
    618
    I see a vast improvment doing the squeeze on my 32", and I'm using the service menu.
    edit: The geometry gets messed up (sides of the picture curve) and I can't figure out how to adjust it, but it's worth it.
    "We're trying to make a movie here, not a film!"
    [Edited last by Steve Felix on September 09, 2001 at 02:19 PM]
  6. Richard Kim
    Richard Kim Producer
    Jan 29, 2001
    4,385
    I noticed a big difference on my 27" VVega, the image looks alot crisper, and I notice the tiny details in fabric and clothing of the characters, which would look fuzzy in 4:3 mode.
  7. Sanjay Gupta
    Sanjay Gupta Supporting Actor
    Jun 30, 1997
    753
    Sanjay Gupta
    Before I got my 32" Widescreen (16:9) TV I used to have a 29" Sony TV with the Anamorphic squeeze feature. Well, atleast to me there was a world of a difference between an anamorphic and a non-anamorphic dvd even on the 29". I don't remember even one person not noticing the difference when I showed them a DVD with both options.
    Sanjay
    Member since 1997
    [Edited last by Sanjay Gupta on September 12, 2001 at 02:12 PM]
  8. Kenneth English
    Kenneth English Second Unit
    Sep 29, 1999
    418
    I definitely notice the difference on my 32" WEGA in anamorphic mode. I think it depends a lot on the TV itself and not necessarily just on the fact that the movie is anamorphically-enhanced.
  9. Jim Robbins
    Jim Robbins Stunt Coordinator
    Sep 3, 1998
    233
    I see a big difference in a 2.35:1 on my Wega 27". I do beleive that anytime you increase the raster lines in a given area, the picture just looks better. PAL is a good example since the bandwidth is about the same, the 625 horizonal lines make a big difference in the smoothness of the image.
  10. Jason Merrick
    Jason Merrick Supporting Actor
    Mar 2, 2000
    696
    Simi Valley, CA (Los Angeles)
    Jason Merrick
    I can see a fairly big improvement on my 27" JVC when using the service menu squeeze trick. I just wish dvd's that are anamorphic 16:9 would also put the extras in amamorphic 16:9!
    [​IMG]
  11. Tom Oh
    Tom Oh Second Unit
    Jul 11, 1999
    253
    For the life of me, I cannot tell the difference on my Panny 42" plasma. My dvd player is Sony 9000ES. I switch back and forth on 9000ES yet cannot find a difference between interlace and progressive. I looked at the scenes from 2001 and Saving Private Ryan as suggested by HTF members. Am I doing something wrong or is there little difference with certain TVs. I thought I remebered reading that some TVs line doubling is as good as DVD player's progreesive. Please help me to understand.
  12. Adam Tyner
    Adam Tyner Screenwriter
    Sep 29, 2000
    1,410
    When I upgraded from an analog 32" to a 36" VVega, the difference was almost night and day. Part of that, though, is probably because I have a Toshiba player, notorious for its downconversion artifacts...
    My DVD list | My personal site
  13. Roland Wandinger
    Roland Wandinger Stunt Coordinator
    Feb 13, 2000
    220
    There is much of a difference on my 91' wide screen. So much that I don't buy anymore non-anamorphic DVDs.
  14. TheoGB
    TheoGB Screenwriter
    Jun 18, 2001
    1,744
    Woah Roland. That's a 91 FOOT widescreen TV is it? Or is this just a Spinal Tap moment? [​IMG]
    Either way it's bloody impressive.
    I really notice the difference between non-anamorphic and anamorphic on my 24" Sony Widescreen.
    Jason: I only own two titles with anamorphic extras that I know of: Spaced (UK TV series - one of the best DVD's I own for extras and everything) and Seven SE. I think Austin Powers The Spy Who Shagged Me may also be anamorphic for all extras. Fight Club may be but I've not watched the extras since I upgraded to widescreen.
    Theo
  15. DaViD Boulet
    DaViD Boulet Lead Actor
    Feb 24, 1999
    8,800
    3
    Those of you with small monitors...it also depends on how close you sit to your set. 16x9 discs let you get close because of less visible scan-line artifacts.
    quote: For the life of me, I cannot tell the difference on my Panny 42" plasma.[/quote]
    That's because your display probably has a really good scaler. Unlike most CRT-based displays which merely "zoom" or magnify a 4x3 lbxed image by blowing it up (thereby making the scan-lines more obvious), your set actually digitally resamples/scales the image to interpolate 4 scan-lines in place of every 3 scan-lines of the 16x9 picture area in the 4x3 lbxed signal. Essentially, your set is sythesising a 16x9 image.
    I have a CRT TV that behaves like your plamsa (ProScan 34" direct-view). I've always thought this means of dealing with 4x3 lbxed (digitally interpolating lines) looks a LOT better than the way most crt-displays just "zoom". I can still see an improvement with 16x9 discs...less aliasing on diagonals and by and large a slightly more "film-like" image...but many 4x3 lbxed images look good too.
    All things being equal, more resolution in the source signal is better. I'll bet if you sat a little closer to your plasma you'd begin to see more obvious differences between 4x3 lbxed and 16x9 images. I've noticed that with some 16x9 discs with really supurb transfers I can sit just 1.5-2 screen-widths away from the tube and I get an amazing picture. No matter how good I think a 4x3 lbxed transfer looks from the couch, it always degrades when I get that close.
    -dave
    [Edited last by DaViD Boulet on September 13, 2001 at 12:13 PM]
  16. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    rookie question: what exactly is this anamorphic squeeze feature? if anyone has info or links i would appreciate it!
    tia
    You step in the stream,
    But the water has moved on.
    This page is not here.
  17. Sean Patrick
    Sean Patrick Supporting Actor
    Apr 22, 1999
    732
    botttom line for smaller-tv owners like me that have tv's with 16:9 squeeze - you do notice a good leap in detail when compared to downconversion artifacts of even the better dvd players. However, we probably don't notice as many of the atrocities present in nonanamorphic transfers as those with bigger tv's.
  18. Jason Merrick
    Mar 2, 2000
    696
    Jason Merrick
  19. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    thanks jason! [​IMG]
  20. TheoGB
    TheoGB Screenwriter
    Jun 18, 2001
    1,744
    Cheers. I saw Unbreakable at a preview screening and was totally torn on it. I think if the set had included a commentary (darn, maybe it does!) I might have bought it.
    Personally I felt the first three-quarters would have made a brilliant pilot for a mini-series, culminating in the final section some six eps later, if you see my point, and I felt it was a shame that they made a movie out of it. (Though I realise it was never envisaged in any other way, of course.)
    Theo
