? how are you generating the " HZ" signal for calibrating?
Discussion in 'Archived Threads 2001-2004' started by DennisZ, Jan 31, 2002.
  1. DennisZ
    DennisZ Agent
    Dec 14, 2001
    49
    Question how do you generate the "HZ" signals for calibrating? I have seperates and it does not generate these.
    I do have the different disk S&V and video essentials
    If I calibrate my subs new SVS 20-39+s with the Samson
    S1000 amp using these I can get the subs to 85 db with no problem.
    I also tested with the THX intro on TFM and it pegged
    the meter set at 100. The air volume and rush was just
    incredable.
    thanks all help greatly appreciated
    Denny
  2. Greg_R
    Greg_R Screenwriter
    Apr 9, 2000
    1,996
    Portland, OR
    Greg
    The goal of calibration is to ensure that the subwoofer level is balanced with the mains (in terms of SPL). When you play the test tones on VE, make sure that each speaker (mains, surrounds, sub, etc.) reproduces the sound at the same level. If you have your receiver's dial set to "00" when you calibrate, you'll calibrate to reference levels (75 dB with VE, 85dB with Avia).
  3. DennisZ
    DennisZ Agent
    Dec 14, 2001
    49
    OK thanks Greg. I have that set
    Denny
