Household electrical wiring question - switched outlet.
Discussion in 'Archived Threads 2001-2004' started by Ted Lee, Dec 30, 2002.
  1. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    hi all -
    i guess my sister was trying to replace some of her older wall outlets with the newer modern (square shaped) ones. anyway, i guess one of the plugs was on a switched outlet.
    when she replaced the plug, the switch stopped working. according to her, both outlets have power...just not the switched capability.
    i asked her if there was a red wire - which typically is connected to a switch (isn't it?) - she said no.
    i haven't been over to her house yet to investigate, but i just thought i'd ask if anyone had any ideas?
    thx,
    ted
  2. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
  3. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    thx todd. i think i know what type of plug you're talking about.
    i still don't get how can *both* outlets (top and bottom) can have power, regardless of the switch's position?
    where is the wire leading from the switch to the outlet?
  4. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
  5. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    cool diagram jeff.
  6. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
    If you don't break the connection, and have both the switch and hot connections (both blacks) connected, the switching is negated, since power is always connected.
    Chances are she just reconnected it the way the old plug was, but didn't break that connection.
  7. Ted Lee
    Ted Lee Lead Actor
    May 8, 2001
    8,390
    ahh...that's the key i was looking for. thx jeff! [​IMG]
