House of the Dead III and HDTV support
Discussion in 'Archived Threads 2001-2004' started by WillY, Oct 8, 2002.
  1. WillY
    WillY Stunt Coordinator
    Sep 11, 2000
    189
    I love gun games, and was really disappointed with the Guncon II for PS2 because it didn't work with my Sony XBR450. Anyone know if the XBox guns will work with HDTV's?
  2. Kelley_B
    Kelley_B Cinematographer
    Feb 27, 2001
    2,324
    if its a RPTV, then more than likely no.
  3. Jeff Kleist
    Dec 4, 1999
    11,267
    Consumer RPTVs just are not light gun friendly
  4. James Zos
    James Zos Supporting Actor
    Jan 7, 2002
    725
    Damn! I plan on buying a front projector and was really looking forward to playing this game in particular! What about front projectors and light guns? I'd imagine the same limitations would apply?
  5. Romar Armas
    Romar Armas Second Unit
    Oct 17, 1999
    276
    When I had my Dreamcast, I had to purchase the VGA -> Component transcoder from Audio Authority and play House of the Dead 2 in VGA mode on my TW40X81.
    Since almost all games support 480p on the Xbox, I assume that House of the Dead III will support it also. If this is true, then the Light gun will surely work for TV's that upconvert the signal to 480p!
  6. Todd_B
    Todd_B Second Unit
    Jul 16, 2000
    381
  7. Michael St. Clair
    May 3, 1999
    6,001
    Light guns work fine with many (but not all) NTSC RPTVs.
    However, a game must be specifically coded to support 480p.
  8. Leroy
    Leroy Second Unit
    Jun 30, 1997
    305
    I've always though that this was odd. Since almost every arcade gun game seems to use a rear projection monitor ie. Time Crisis 2, Jurassic Park, Brave Firefighters etc..are these special monitors?
  9. Jeff Kleist
    Dec 4, 1999
    11,267
    Leroy, 1-Those are turned up to torch mode, and 2, all versions of the game use the same equipment,which can be custom tuned for the guns
  10. Dave W
    Dave W Stunt Coordinator
    Mar 28, 1999
    142
    Just wanted to add that I have played gun games on my RPTV on both Dreamcast and PS2 but they always loose calibration in like 5 minutes. [​IMG] HoTD2 is a great Dreamcast game but I did eventually move it to the little 32" Sony in our front room instead of big screen. I gave up on light-gun games on PS2 as the damn Guncon2 connections (Both controller port and USB, Composite video connection) are a nightmare and always seem to mess up my DVD remote on PS2...
  11. WillY
    Sep 11, 2000
    189
    So what about direct view HDTV's? My Sony is a direct view, not a projection TV.
    And what are some examples of 100 MHz TV's?
  12. Sean Patrick
    Sean Patrick Supporting Actor
    Apr 22, 1999
    732
    i am also very curious about this - i have a direct view HDTV (F38310) and HOTD 2 for my dreamcast did not work via s-video.
    I was hoping Time Crisis 2 would work with my PS2 via component inputs but a comment in this thread seems to suggest otherwise.
    So, if HOTD3 for Xbox isn't at least 480p, it won't work with hdtvs? what if's 720p and gets downconverted by tv's like mine? i don't think i'm going to buy an XBOX if i can't play HOTD 3.
  13. Sean Oneil
    Sean Oneil Supporting Actor
    Mar 19, 2001
    931
    Count me curious.. I want this game, but want it to work with the light gun on my Mits 55857 in 480p mode.
    If anyone has info on compatability with this model TV, I would appreciate it being posted here.
    Thanks [​IMG]
  14. Chris Rock
    Chris Rock Supporting Actor
    Jan 10, 2001
    710
  15. Michael St. Clair
    May 3, 1999
    6,001
    When HOTD3 comes out (tomorrow?), I'm going to buy a copy at EB, and if it doesn't work I'll return it (and the gun) immediately for a full credit.
    Of course I'll report my experiences here.
  16. Romar Armas
    Oct 17, 1999
    276
    I really don't see why the guns won't work on an HD set using the HD pack.
    I had no problems with the Dreamcast + VGA -> Component converter + TW40X81. Played the heck out of House of the Dead 2. Too bad the Dreamcast Mad Catz guns were POS and both of them broke after being used too frequently.
  17. Michael St. Clair
    May 3, 1999
    6,001
    Ack, I just found out the Madcatz XBox gun is $40! I think I'm going to wait a few weeks and see if anybody else announces one.
    You know, for the PS2 I can get a game with a quality Namco gun for $55. $90 is way too much for a game and a shitty Madcatz gun.
  18. Jeff Kleist
    Dec 4, 1999
    11,267
  19. Michael St. Clair
    May 3, 1999
    6,001
    It's the code more than the guns...most lightguns are not smart at all, they are just a photosensor. But the game code needs to handle the different scan rates, blanking, and so on.
    I doubt if you take apart a Dreamcast gun or an Act Labs PC gun (both of which work with 480p) that you'll better photosensors or circuits.
    Throwing in sets that can convert the scan rates (like 480i to 480p or 960i) requires the code to be even smarter. HotD2 for DC will work fine on a 480p TV via the VGA box, but if you use 480i s-video and let the set convert to 480p, it will not work. Why? The gun doesn't care, but the code isn't smart enough to handle it.
  20. Romar Armas
    Oct 17, 1999
    276
    I always thought the main reason was in the case of HOTD2 in the DC is the Code is set to 480i. However, the TV automatically upconverts the signal to 480p. So the code is computing the 480i timing however, the tv is at 480p so it's a mismatch.
    However, when you use the VGA box, the code is doing 480p since the output is progressive. The tv is doing 480p so everything is fine.
    If HOTD3 supports 480P using the HD pack, then there should be code there to support 480P thus the gun should work fine. But, if HOTD3 only has support for 480i then it won't work.
