Hot Shots widescreen framing...cut a lot off
Discussion in 'DVD' started by Aric Friesen, Jan 11, 2004.
  1. Aric Friesen
    Aric Friesen Extra
    May 14, 2002
    23
    Ok, so anyone else notice how much of the frame (well the sides at least) are cutoff from the widescreen version of Hot Shots on DVD?
    It's very apparent in a scene where a mechanic (working for the bad guy) uses a wrench in his hand and motions for a fighter jet to take off (don't ask for a time in the movie, I'm not near my DVD right now). Anyway, the site gag, is the jet takes off and the guy is all burnt up and jumps off the side of the aircraft carrier to get into the water.
    Point of this is, in the movie the guy is visible holding his large metal wrench which has melted from the fire. In the DVD his hand is cutoff on the right side of the screen so you don't even see the wrench.
    Anyone else notice this? Is it normal to have that much cut off on a widescreen movie? I just got my replacement Back to the Future II and III DVDs from Universal and was hoping that would be the last time I saw a framing issue on a widescreen DVD.
  2. Patrick McCart
    Patrick McCart Lead Actor
    May 16, 2001
    7,555
    186
    Georgia (the state)
    Patrick McCart
    Hot Shots was likely filmed "full aperture" on 35mm film... meaning the film's negative would have a 1.37:1 frame, which would be matted (by the aperture plate) by the projector in a theater. For video, the 1.37:1 image is matted to 1.85:1 for DVD. This is the case for most 1.85:1 films shot on normal 35mm.
    In fact, for EVERY film, cropping is required to present not only the correct aspect ratio, but the correct framing.
  3. Joe Schwartz
    Joe Schwartz Second Unit
    Nov 2, 2001
    449
    Patrick, he's complaining about the sides of the image being cropped, not the top and bottom.
  4. Aric Friesen
    Aric Friesen Extra
    May 14, 2002
    23
    Yep, it's the right side that I noticed specifically.
  5. Lev-S
    Lev-S Second Unit
    Jun 29, 2003
    324
    I have not noticed this and I own both the MAR VHS and OAR DVD edition of Hot Shots and it's sequel. I'll have to check it out...
  6. Stephen_J_H
    Stephen_J_H All Things Film Junkie
    Jul 30, 2003
    5,526
    838
    North of the 49th
    Stephen J. Hill
    Is your system properly calibrated? I noticed with my monitor that a lot of the left side was cut off, until I adjusted the overscan on it. Just a thought.
