Hoping to watch Super Bowl in HD. Will these antennas work?
Discussion in 'Playback Devices' started by BrentJ, Feb 4, 2005.
  1. BrentJ
    BrentJ Second Unit
    Apr 27, 2002
    329
  2. Hank_P
    Hank_P Second Unit
    Nov 15, 2000
    321
    19
    110
    I think the first is similar to the Zenith model. I am familiar with that one and it works very well. I'm not familiar with the second. My vote goes for the first one.
  3. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Check www.antennaweb.org to see what kind of signals you can get. The first antenna looks like the famous Zenith Silver Sensor.
  4. JeremyErwin
    JeremyErwin Producer
    Feb 11, 2001
    3,218
    2
    Indoor Antennas don't fit in the antennaweb classification scheme. That's not to say that antennaweb is useless-- if nothing else, it gives you a nice bearing to the transmission tower. A (very) few stations transmit their DTV signals on the VHF bands, so if your fox affiliate is one of those, getting a fancy UHF-only antenna would be counterproductive.
    Most indoor antennas contain only a few antenna elements-- but some of the more expensive antennas combine the barebones loop and rabbit ears with a strong (though noisy) amplifier. The Silver Sensor is unamplified, but it does have quite a few elements. Perhaps the "Garbage In, Garbage Out" dictum applies here.
  5. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,751
    482
    9,110
    If you are in the yellow and green zones, try looking for the Double Bowtie Antenna that can be found at Radio Shack, it's what I use (along with a small 20dB antenna booster) for UHF ATSC (HDTV) reception.
  6. JeremyErwin
    Feb 11, 2001
    3,218
    2
    Comparing the common antenna types. Note that "small indoor loops" fare particularly poorly. The common availability of cable and especially satellite limits the availability of the more exotic designs, though I was able to find a silver sensor at Sears. You may have to specially order the double bow.
