Kip P.
- May 23, 2019
- Keith
Where are you located? Some members here have been very generous about opening up their homes to demo gear for their fellow members. Unfortunately for a variety of very boring reasons I can’t host at the moment, but maybe someone else can.
@JohnRice is great with the speaker stuff. He was very helpful in translating marketing speak and tech terms into actual English for me years ago when I was buying mine.
I have a little bit more knowledge (but far from being the most expert voice here) on projectors. I have an Epson 5030 from a few years ago, which is a 3D-capable HD machine that works just as well now as it did when I got it five years ago. Their newest version of that model, the 5050, was just released to great reviews. The 5050 is a 4K projector that can also do 3D (which can actually be way more impressive with home projection than in theaters), and is about $3000, maybe a little less. I’m really a fan of the Epson 5000 line and think they’re worth looking at, especially if you’re on a budget. In my opinion, with an Epson, you typically get better bulb life than on some other brands, and their replacements tend to cost a little less. They’re bright, which makes them great for all sorts of rooms and screen sizes. They can easily throw a huge image. They also have a generous lens shift, more than any other brand, which gives you tremendous flexibility in where you can place it in the room. A lot of other projectors have much stricter placement requirements, which can suddenly eat into your budget in unanticipated ways if you’re stuck with a machine that needs to be hung in an inconvenient spot.
There are other great projectors out there too, so don’t necessarily limit your search to just that one, but definitely take a peek.
Figure that out of everything you buy, the speakers have the potential to last the longest - possibly decades. For a projector, it seems home video standards change every ten years or so these days (and that pace may be accelerating) but barring the invention of cheap home holograms, your projector will probably last you more than five and hopefully closer to ten years. The receiver and individual media players (disc player, streaming devices, etc) will be the things that get replaced more frequently, so my other advice would be to not sink the bulk of your budget into those items. That’s not to say you should get the cheapest thing possible but if you’re trying to stretch your dollars, it doesn’t make sense in my view to buy (for example) a cheaper projector so that you can spend more on a nicer UHD disc player. It’s probably the same with speakers and receivers. The speakers will last longer than your receiver so budget for that accordingly.
Now, this thread is really moving ... thanks to both of you.
I live in Eugene, Oregon. (University of Oregon Ducks
I'm taking notes on the speakers and the projector, so far.
Quick question: Since my room isn't very long ... or tall, should I consider Ultra Short Throw projectors? (17" from the wall.) Short throws? Or regular? Or are those terms obsolete?
Thanks again,
Kip
