I have the following:
Sony 57" widescreen HDTV compatible TV
Sony Progressive scan DVD
ReplayTV 5080
HK 520 amp
Motorola ATT HDTV cable box.
Currently I have the following setup
cable box to the TV using component video cable
cable box to the RepayTV using standard audiovideo R/W/Y cable
ReplayTV connected to TV using standard audiovideo R/W/Y cable
DVD connected to the TV using component video cable
DVD connected to the amp using the digital audio cable
the only think running through the amp is the DVD, but I would like everything to go through the amp.
Could I use component video cable runing from cable box to replayTV to amp and then to TV. From DVD to amp to TV. Or should I look into s-video
thanks in advance
ReplayTV 5080
HK 520 amp
thanks in advance
