Darren_Fu
- Jun 7, 2002
I just need to know the best way that people on this forum, that have the Panasonic DMR-HS2 DVD Recorder, hooked it up to a regular VCR. I am interested on switching over some old VHS home movies over to DVD but the instructions as how to hook up the DVD Recorder to a VCR are sketchy. There is actually a little Warning Box in the instructions that state not to hook the dvd recorder up going through a vcr. If you don't do it that way then how do you do it?? All I wanted to do is to transfer the home videos from the vhs tapes onto the hard drive then from the hard drive to a dvd-r. Any help on how to set up the dvd recorder and vcr to work together to accomplish this would be very helpful. BTW, the vcr is a panasonic but it is an older model from like 1993. I also need to know if that will be a problem.
Thank you,
DF
Thank you,
DF
