Darrel McBane
- Oct 8, 1999
I'm wondering if anyone who has a Loewe or seen a Loewe Aconda hooked up to HD by way of a cable company's' connection digital box? I have a cable guy coming out Tuesday to hook up to mine. HD HBO and Showtime are now available in my area.
I'm thinking most TVs use component connections to a set. But, since the Loewe will take the signal and use its progressive scan doubler on a component connection. Then the only way to bypass the internal doubler is to use a VGA connection. When I called the tech area if you want to call them that...to be kind. Said that it just hooks up on the regular TV cable. When I called a local store that sells the Loewe. They said that a component to VGA cable is required. It will take up to three weeks to get one in their store.
Our cable company is ATT Broadband which merged with Comcast cable ( I think it's Comcast? ). So I think the same box should be used pretty much country wide?
When I bought my Loewe I wanted to bypass the internal doubler so I could use my Sony 9000ES progressive scan DVD players doubler. So I bought a Audio Authority transcoder box. I'm thinking this will allow me to hook to the set via component to VGA connection?
Any thoughts on this?
