hooking up dual subs (1 Viewer)
If I want to hook up dual subs can I use a y splitter off of my LFE output on my reciever (Kenwood 6070). Or is there a better way?
Greg Bright
Gregory Bright
It's what I've done. The only other option would be to daisy chain them provided one of the subs has an output for that.
Wayne A. Pflughaupt
Corpus Christi, TX
Wayne
Daisy-chaining will also work using the splitter on the sub end. The sub doesn’t need a line output. Just plug the splitter into the sub’s input; one side goes to the receiver, the other to the second sub.
Wayne A. Pflughaupt
MJL
