Linus
- Jul 10, 2002
I purchased a KSW-15 last night for my HT. I've got a Denon 2802 that i'll be hooking it up to today.
I'm wondering how exactly i should hook it up to the receiver. There seems to be two different ways to do so. First there are pass through speaker wires where you can run your Front channels into the sub, then run the output into the front speakers.
Then their is the Subwoofer single RCA output LFE jack. From what i understand is the LFE ONLY sends bass special effects of a 5.1 encoded movie to the subwoofer, but nothing else during the play of normal CD's, TV, VHS, and regular DVD's?
So it seems the best way is to hook up both? My other question is do i use the Front or Rear speaker output from the receiver to go into the subwoofer? Also i have a "b" selection from the receiver with an extra set of terminals. Is this intended for the subwoofer? Or just for using a second set of speakers in general.
I've noticed reading the post here that you should set the speakers to "Small", which will only send bass signals to the subwoofer. But will it only send that signle to a LFE? Does this only work on 5.1+ solution and not normal TV or Music? I'm just wondering how it deciphers the signal it the sub is hooked up to the front/rear channel.
Thanks for any and all answers, i'd really appreciate any guidance because i'm new at this. I know car audio in and out, but setting up home audio is a bit different and i just want to do it right!
