Hooking DVD Player up to TV (speakers) question
Discussion in 'Archived Threads 2001-2004' started by Dave H, Jul 3, 2002.
  1. Dave H
    Dave H Producer
    Aug 13, 2000
    5,614
    238
    9,110
    I bought a Panasonic RV-32 for my 27" bedroom TV. Since I am using my TV's speakers, I want PCM downcoversion, right? And I want bitstream turned off? Thanks.
  2. Bruce Chang
    Bruce Chang Second Unit
    May 10, 2002
    283
    You want to use the standard composite cables. The red Right audio channel, white Left audio channel, and yellow for video. Radio Shack should have the wire you're looking for.
  3. Dave H
    Dave H Producer
    Aug 13, 2000
    5,614
    238
    9,110
    But, in the audio menu option of the player, I need to set the areas I mentioned. What do I set to?
  4. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Doesn't matter.
    The PCM downconversion vs. bitstream setting ONLY affects what comes out of the digital output on the player. If you set to PCM downconversion, then the optical/coax connection will get a downconvered 2 channel signal.
    The analog outputs on the player will supply a 2 channel downconversio no matter what you choose in that menu (as that is all they can supply).
    Again- that setting only affects the digital outputs and will have no baring on your connection via analog outputs to your TV.
    Hope that helps.
    -Vince
  5. Dave H
    Dave H Producer
    Aug 13, 2000
    5,614
    238
    9,110
    Thanks for the help.
