CoachK
- Mar 6, 2004
I have a Denon 3800AVR and Sony Grand Wega XBR, with Denon DVD with Dish network, no cable tv.
I have hooked my dish using coaxial from converter box to TV along with routing S-video from converter box to Denon 3800AVR. I have routed both S-video from Denon 3800AVR and component hookups using the monitor out.
From my DVD, I have optical hook up, component plugs going to the 3800AVR, and composite going from DVD to TV.
Problems: MY TV only gets picture on Dish using the coaxial connection from the Dish, and only a picture from the composite connection from the DVD.
I thought by routing everything through my 3800AVR that the picture would go through it to the TV....Is this thinking wrong?
What should I do?
option 1) route component cable directly from the DVD to TV and S-video from Dish to TV and bypass video conections through the 3800AVR?
option 2) Do above and also route Video through the 3800AVR.
Sound works great and I don't have any problems that I am aware of with sound.
Thanks for any help!
Coach K
What should I do?
Coach K
