papashady
- Oct 1, 2006
- Brad
Hi,
I really need help hooking up my set-up, any help would be great!
I have the following:
-50" Plasma Pioneer purevision (has two hdmi, and two component)
-HDTV comcast box (has 1 component, and no hdmi)
-Samsung HDMI dvd multi-format recorder (has 1 hdmi and 1 component)
the dvd recorder has a IR cable to get the cable box's channels, but I don't know how to do it.
I have the following cables available:
1 hdmi
1 component, which I need from the Comcast box to the tv in order to get the HD channels
3 red/white/yellow
3 av cables
1 IR cable
I want it set up so i can record tv programs with my dvd recorder, and still be able to watch dvd's with the upconversion hdmi. Is that all possible? Do I need any other cables? Do I need to run the cable line to comcast box, then how do i record tv programs? I feel really dumb! I need like every step told or I get confused. PLEASE HELP!!!!
Thanks for your help I really appreciate it!
-Brad
1 hdmi
3 red/white/yellow
3 av cables
1 IR cable
-Brad
