Ed Kerns
- Jan 15, 2005
Hi, and thanks very much to you veterans for this forum. I've learned so much just by reading other posts, but still I have a question about my newly acquired HT gear.
Of immediate concern is a motorola HD cable box, a new Onkyo series 800 receiver and a Toshiba 'HD ready' projection TV. From my cable box I have run component video to the receiver then from the receiver, component video to the TV. It's my understanding that this is the best method of getting the highest quality signal to the TV. I have also linked all the boxes with digital cable for audio.
My problem is, by using all component hook ups, I can not (according to the receiver manual) get an on screen menu to the TV. I can get it on the front panel of the receiver, but this is a bit inconvenient to view from the easy chair. My question is; can I run a secondary input to the TV, say S-video, and use that input strictly to view the menu? Is this typical? Is there a better way? Will it even work?
For what it's worth, I should add that I already have an analog signal passing through the cable box to the TV. I find this input gives me a better picture on non digital TV programming. Thanks again, and sorry for the long post. Ed
