Homecinema Projector for a small room
Discussion in 'Displays' started by MosheBH, Aug 10, 2005.
  1. MosheBH
    MosheBH Auditioning
    Jun 26, 2005
    I have a small room in which I intend to install a Homecinema projector. Actually the distance between the projector and the screen will be 12 ft., and the sitting distance from the screen will be slightly shorter. I am worried about the possibility of having a "too large" picture with most of the available DLP projectors, and I find that the "Screen size Calculators" in various web-sites are not so accurate and consistent.
    Any ideas which projector may be suitable?
    Moshe
  2. Jim Mcc
    Jim Mcc Producer
    Feb 11, 2004
    3,757
    38
    Oconomowoc, WI.
    Jim
    It depends if you want a 480p or 720p projector. With a 720p projector you can have a larger screen and sit closer(1.5X screen width). With a 480p projector, you need to sit back about 2X screen width. You should get a short throw projector. Tell us your budget just for projector and your viewing uses.
