btelin
- Feb 1, 2011
- Brad Telin
Bought a home with HT setup, the recevier (old Teac) died. I'm thinking of replacing the receiver with a
Onkyo nr708.
Sub woofer is an Audiosource 10001 - Will this be sufficient? Recommondations if not.
Center speaker needs replacing - recommendations?
I have four of the older small Bose white speakers mounted in the ceiling in each corner of the room. Will these work or should they be replaced. Should I add a couple front speakers in additon to the center. Recommendations?
TV is Toshiba Regza 56"
Any recommendations would be helpful.
Onkyo nr708.
