Derek_Sutherlan
Grip
- Sep 14, 2004
Hello everyone,
I recently began the process of planning a dedicated Home Theatre. The room in question is approx. 10'wide, 12'long and will employ a 7.5' drop ceiling. Leading into the theatre will be a 4 to 5 foot wide hall designed to house equipment and DVDs. You can view the proposed layout on Wes' website (Wes, if you are reading this, maybe you can provide a link).
Currently I am getting quotes on a Sanyo Z2 with a 92" Da-lite screen. I am also looking to buy new speakers...in particular, the Athena ASB2s (2 or 4) R-1 (2) and C-1 (2). I am not sure if that will be overkill with the dimensions of the room. I haven't settled on a receiver/amplifier or subwoofer yet, but I figure those items can be determined once the room is complete.
So here are my questions:
1) i am thinking of carpeting the floor and the bottom third of the walls (good or bad idea?)...should i carpet the entire wall(s)?
2) does anyone have an opinion on the sanyo z2 with regard to the room dimensions and/or the athena speakers.
3) i was planning on employing a pocket door to close off the room (i really don't have the room for a door that swings) ... good or bad idea?
4) if i put movie posters (framed with non reflective glass) on the side walls (3 on each) will this improve or distort sound?
i know this is a long post, but finally,
5) can anyone recommend a subwoofer(s) set-up for this room
thanks,
Derek Sutherland
Midland, Ontario
thanks,
Derek Sutherland
Midland, Ontario
