Home Theater Subwoofers....Forward or Bottom Firing???
Discussion in 'Speakers & Subwoofers' started by John Doh, Aug 5, 2003.
  1. John Doh
    John Doh Stunt Coordinator
    Jun 24, 2003
    199
    Which is the better performer if they were rated the exact same as far as power, size, etc.? What about in a carpeted, 12x13-foot room? Thanks!
    ~ BTW, the two that I am considering are the JBL PB12 and the JBL S120PII. All my HT speakers are of the Studio series, and need to know which sub to get. There is only about a $120 difference (S120PII is more) and they are both 12" subs. One fires forward while the other fires down. Thanks!
  2. Lee Carbray
    Lee Carbray Second Unit
    Oct 23, 2002
    308
    I don't have any practical experience directly comparing down and front firing subs but from all that I have ever read there is no difference in performance.
    I am not familiar with the JBL subs so I cannot directly comment on them. I did just read in another thread that the new issue of Home Theater will have a review of a handfull of subs including the S120PII.
  3. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    I would get the S120 because it has more power and more bass capabilities. I think it's worth that extra amount of money.
    I don't see any performance differences between FF and DF subwoofers.
  4. Joe Spratley
    Joe Spratley Stunt Coordinator
    Aug 5, 2003
    107
    John, I got mine for $300 at BB open box. They seem to be closing them out. You might want to check there.
  5. John Doh
    Jun 24, 2003
    199
    Joe, which one did you get for $300? Thanks!
  6. Joe Spratley
    Aug 5, 2003
    107
    John, the s120pII
  7. John Doh
    Jun 24, 2003
    199
    Wow, thats really cheap!! How does it sound? Also, where do you have placed in your theater room? Is your room an even square/rectangle? Thanks!
