For hookups, just remember that the receiver is the "hub" of the system, therefore:
- Audio and video from every source to the receiver (HDMI carries both signals, so only 1 cable for those devices).
- A single HDMI cable to carry video out from the receiver to your TV.
- Connect your speakers to the correct terminals on the back of the receiver, making sure to match red with red and black with black at both the receiver and the speaker.
The 5800 will upconvert all incoming video signals (even the composite, standard-def video signal from your VCR) and output them via HDMI. This makes your life easier, since you don't need multiple video outputs, etc.
However, since the DVD/VCR device will have separate connections for video and audio, at some point during the setup, you'll have to tell the receiver which audio input corresponds to the DVD/VCR video input. The manual should help with this.
A note on the speaker connections: The front L/R speakers use binding post connections on the back of the receiver. If you've not used binding posts before, you strip the speaker wire just like for the clip terminals, but you unscrew the red or black plastic binding posts to reveal a hole in the side of the central (metal) post. Stick the bare wire through this hole (it will be sideways to the binding post), then tighten the binding post back up to hold the wire in place.
Connecting to binding posts can be very difficult to do if the receiver is already on a shelf or in place and you try to do this upside down, on your back, or with a flashlight, etc. If possible, I would suggest disconnecting the wire from the front speakers and attaching them to the receiver before putting the receiver on the shelf. It'll likely be far easier to fish the speaker wire back to the main speakers than fidgeting with thin wires and tiny holes in the dark, lol.
Just take your time and review the manual before you start as well as during the process.
We'll be able to help with any problems you encounter. Good luck and have fun!
