Home theater in a box question
Discussion in 'Beginners, General Questions' started by Chris Gwin, Mar 1, 2004.
  1. Chris Gwin
    Chris Gwin Auditioning
    Feb 28, 2004
    2
    Hi I'm very new so please bare with me. I just got a samsung theater in a box. I was very happy with it when i first got it but I am now noticing distortion. I hear it mostly on higher pitched sounds(violins, trumpets, voices. I contacted Samsung and they believe I should have the amp serviced, which will cost a lot for a brand new machine. What should I do?
  2. Mike Fassler
    Mike Fassler Supporting Actor
    Jan 17, 2004
    523
    at what volume level are you noticing this distortion? the speakers may not be able to be pushed to hard.
  3. Sean Conklin
    Sean Conklin Screenwriter
    Oct 30, 2000
    1,720
    I wonder about the capability of the HTiB speakers tweeters too. Have you tried diferent speakers? Might save you some down time sending in the amp.
  4. Chris Gwin
    Feb 28, 2004
    2
    yeah I'm trying to figure out if it's speakers or amp. To answer your question on volume, 50 being the highest I hear this distortion around 20, so not very loud
  5. Sean Conklin
    Oct 30, 2000
    1,720
    Can you borrow some good speakers from someone to test this?
    Loudness is subjective, do you mean like way below reference levels? roughly 75dB?
    Do you have your speakers set to "small"?
