JackB
Grip
- Mar 31, 2003
I am unfortunately restricted to a relatively small room for my dedicated home theater. The maximum width it can be is 11', ~18' in length, 7'6" to 7'9" in finished height. The projector could be mounted in the room behind the theater and project though a hole in the wall if that would help. I am soliciting comments on how to lay this space out properly seating, projector placement, screen size, etc. any comments will be helpful and appreciated.
Other info. that may be be important:
Projector: Sharpvision XV-9000 FP {dlp}
Receiver: Pioneer VSX-29TX
Speakers(crappy I know, when I win the lotto I'll replace them):
BOSE AM-7s for front speakers
{replaced center speaker with Bose VCS-10 that is wired directly to center channel output not through the passive sub}
BOSE AM-3s for rear left and right.
Two 12" KLH 200 watt subs{Bose passive subs don't provide much bass}
Disc Player: Pioneer DVL-91
Theater in in half basement.
Walls: Rear wall partially finished, sheet rock, with r-13 insulation, open closet area where I plan to place the equipment, would appreciate advice on shelving/
racking/venting this in economical manner. Right side wall unfinished, poured concrete, has one window close to the end of what will be the finished room(too be closed off. I'm not sure how I should insulate this, I was going to apply 3/4" of foam board, maybe cover it with roofing felt. Screen end of wall is not built yet, can not afford steward screen, will paint wall with GOO product or something, maybe a regular paint can be suggested flat, glossy, ???, gray? Left wall will be built to enclose metal support posts supporting main/first floor( I was planning on sheet rock.
Furniture has not been purchased, but I won't be able to spend 500 bucks a seat to accommodate viewers. Probably a second hand couch or two picked up at a yard sale.
