Home Server?
Discussion in 'Archived Threads 2001-2004' started by gregstaten, Jul 1, 2002.
  1. gregstaten
    gregstaten Supporting Actor
    Aug 1, 1997
    608
    3
    110
    I'm gradually beginning to realize that putting a home server in is beginning to make sense. Here's what I'm looking for:
    RAID 1 or RAID 5
    At least 200 to 300 GB (what can I say - I have a lot of music and video I want to keep online).
    I don't need support for lots of users. In fact, I would imagine that most of the time (while I'm at work or asleep, for example) the number of users will be zero. Most of the time there will be one or two users and occasionally three.
    Cost is certainly a consideration - I don't need a heavy iron server - just one with lots of drive space and RAID support. I'm not even tied to any particular OS as long as it is easy to manage.
    Anyone put something together or found something worth looking at?
    Thanks!
    -greg
  2. ChrisLee
    ChrisLee Stunt Coordinator
    Sep 4, 2001
    104
    Do they even make 200GB hard drives? Because as I understand RAID, you are restricted by the size of the smallest HD in the array. So to have a 200 GB RAID you'd need 2-3 200GB HDs. That wouldn't be cost effective at all (especially if 200GB HDs haven't been released yet...).
    The majority of the people I know say that RAID ain't worth it in the first place. Just get SCSI. At least the data is a little safer there then in a RAID 1.
  3. Greg Rakaska
    Greg Rakaska Stunt Coordinator
    May 16, 1999
    111
    Chris, methinks "the people" you know are not very knowledgeable about RAID. Also, RAID and SCSI are not mutually exclusive, nor related other than being drive technologies.
    RAID 1 (drive mirroring) is one of the better ways to protect data, SCSI is just an interface spec, though a good one.
    It is also quite possible to have RAID configurations larger than the smallest physical drive. Actually, it is quite commonly done. For example, you could achieve 200mb of RAID 1 storage on a SCSI hardware RAID controller by using 8 x 50 mb drives. You would simply mirror the drives in pairs, then using RAID config software, you logically join the four pairs of 50 mb into one 200 mb drive.
    I setup my Oracle servers like this all the time. Probably a bit expensive for home use though, a good RAID controller can set you back a couple of grand (or more) quite easily.
  4. Tim Kilbride
    Tim Kilbride Stunt Coordinator
    Oct 6, 2001
    217
    Greg,
    I have a home server setup...3 HDD (1 OS/programs, 1 for MP3 storage, and 1 for copies of CD's that came with my hardware (so I don't have to keep using cd's if I update anything)). I am running Win2k and I love it...I also have 1 desktop, 2 laptops (mine and the wifes) and I am adding a 4th pc in the home theater (I'm gonna try my hand at building my tivo box). I use a Abit VP6 dual proc mboard and it supports raid arrays on board. I got the mboard for $120 with shipping....I know there are other mboards that do the same...
    My .02
    Tim K.
    [​IMG]
  5. ChrisLee
    Sep 4, 2001
    104
    DOH! I was thinking of RAID 0.
  6. Kimmo Jaskari
    Kimmo Jaskari Screenwriter
    Feb 27, 2000
    1,528
    Take a basic PC, tower model with at least four 5.25 inch slots free in the front fascia (5 slots free would be perfect since you can use one for DVD or CD(-RW))
    Buy two 3-drive hotswap IDE drive cages from 3ware (http://www.3ware.com) or just one now and save two 5.25 inch slots for later addition of another.
    Buy one 3ware Escalade 7850 IDE RAID card.
    Buy three 160GB 5400 rpm drives from Maxtor and configure them as one RAID 5 array (160x3-160=320GB of storage; you lose one drives worth for parity data).
    Presto, a home server with a secure RAID5 disk array, easily expandable when you run out of space by slotting in drives in the second drive cage (if you do get one).
  7. Danny R
    Danny R Supporting Actor
    May 23, 2000
    871
    I'm putting together a terabyte server, as I'm looking to begin saving HDTV captured video.
    Same escalade card that Kimmo mentions ($500).
    Ten 120gb maxtor 5400 drives. Speed isn't a necessity, cheap storage is, and this drive has the best price point as I can get it for $135.
    I'm putting eight of the drives together as a raid-5 array. (no hot spare, no hot swap cages). My goal is storage, not staying up 24/7. If I have to take the server down to replace a bad drive, no big deal. Raid 5 insures I retain my files.
    One drive will stand alone as the boot drive holding the OS and applications. The last drive is the spare (but not installed).
    I'd prefer the server to run a novell netware OS, as I've left my novell servers at work running over a year without problem, and they aren't usually targetted by virii, but 3ware doesn't appear to have a driver for the escalade card. Thus I guess I'll have to go with win 2000.
  8. Dave E H
    Dave E H Supporting Actor
    Apr 23, 2002
    829
  9. gregstaten
    Aug 1, 1997
    608
    3
    110
    Thanks for the info, guys. I looks like I'll try to roll my own. RAID 5 is probably where I'll go as it makes the most sense from a cost/security standpoint. (Note - protection against data loss security.)
    Do you all think it is worth looking at a linux server?
    -greg
  10. Danny R
    May 23, 2000
    871
    Depends on your technical ability. Linux certainly is a good stable option, but it can be difficult to work with if you've never done so before.
  11. Greg Rakaska
    May 16, 1999
    111
    Kimmo,
    Glad to see your reply. I haven't worked with RAID in a home environment. I knew it could be done much less expensively than the Oracle servers I build at work, but I could not offer Greg S. real practical advise.
    I may have to build one of these thingies for my wife and I to store our stuff on. I am ashamed to say we don't always keep our backups as current as they ought to be. While RAID is not a substitute for backups, it does help us lazy folks keep our stuff a bit longer [​IMG]
  12. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
  13. Kimmo Jaskari
    Feb 27, 2000
    1,528
    A linux server makes a lot of sense. You can use a nice journaling file system on the array that way, further increasing your security and speed.
    File sharing can be done with Samba.
    Obviously, this is more work-intensive to get working but is pretty much hands off once its up and running.
  14. Dominic Ryan
    Dominic Ryan Extra
    Jun 8, 2002
    23
    I just finished putting my 300GB server together. Cost me about $2100AUD, which is equal to about $1100USD. It's a PII 350 with 512MB RAM, 10/100 NIC, 2 X 8GB drives for system, and 3 X 160GB Maxtor drives for storage, each with a HDD cooler. Using Windows 2000 Server as the OS, the system drives are configured under software RAID 1, and the storage drives are configured under software RAID 5, giving me around 305GB of RAID 5 storage all up.
  15. Kimmo Jaskari
    Feb 27, 2000
    1,528
    Sounds like a good solution financially, but I would definitely invest in the hardware raid card. Should give massive speed improvements as well as being more secure.
  16. Dominic Ryan
    Dominic Ryan Extra
    Jun 8, 2002
    23
    Yeah, I was planning too, but at the time of buying the equipment, I couldn't find a IDE RAID 5 controller that supported ATA-133. I've got a 40GB DDS-4 tape drive as well, so I should be covered.
