home calibration dics????
Discussion in 'Archived Threads 2001-2004' started by Mikey Ber, Mar 7, 2003.
  1. Mikey Ber
    Mikey Ber Stunt Coordinator
    Oct 30, 2001
    102
    which one do you guys recommend...Avia ...guide to home theater...others? HELP!!!!!!!!
    Mike
  2. ChrisClearman
    ChrisClearman Second Unit
    Feb 5, 2003
    298
    I've heard better things about the home theatre.
    You can get buy w/ using the THX setup on Toy Story or Toy Story 2 and burn your own test tones using programs that you can find on this site: that's what I did.
  3. BobAZ
    BobAZ Stunt Coordinator
    Apr 5, 2002
    76
    See if you like this video analogy:
    THX Optimizer = Composite
    Sound & Vision Home Theater TuneUp = S-Video
    AVIA Guide to Home Theater = Component
    There are 2 versions of the THX tune up. I believe THX Optimizer is for specifically for the movie it came with. Granted, if you've never tuned your TV, it will stil be an improvement. I can't remember what the other version is called and that may be what ChrisClearman is referring to.
  4. Aaron Garman
    Aaron Garman Second Unit
    Oct 23, 2001
    382
    Hello all. I haven't used the others, but I find Video Essentials to be a terrific tool for audio and video calibration. I do use the THX optimizer for a frequency sweep and phase check, but for everything else I use VE. Try it, if you can still find it.
    AJ Garman
  5. JayDaniel
    JayDaniel Stunt Coordinator
    Jun 11, 2002
    114
    I own/use the Sound & Vision HT Tune-up disc. It is made by the same people that made the AVIA disc (Ovation Software). It was cheap ($15). It was very easy to use along with a Rad. Shack SPL meter. It has all the basic audio and video calibrations. I've heard if you have a RPTV, you may prefer the AVIA disc, as it has more calibrations.
    Best $50 bucks I've spent (S&V disc = $15 + SPL Meter = $35).
