HK stereo hookup problem
Discussion in 'AV Receivers' started by Allen Longcor, May 3, 2004.
  1. Allen Longcor
    Allen Longcor Supporting Actor
    Oct 21, 2001
    546
    Ok I have the PT2300 and the connections on the back are not labeled left and right. For example the CD input has no markings as to which is left and which is right, and it is not color coded in any way. The manual is no help whatsoever. Do I assume that the right analog input is the right and the left analog input is the left?
  2. KyleGS
    KyleGS Second Unit
    Feb 12, 2002
    342
    Just plug it in a listen to see if its the correct way. If not --- switch it up. It will not hurt anything...trial and error.
