HK DPR1001 vs. HK AVR series?
Discussion in 'AV Receivers' started by Norris, Jan 20, 2004.
  1. Norris
    Norris Stunt Coordinator
    Jul 14, 2002
    201
    What's the real-world difference between the DPR and say, the AVR 430? Prices are about the same.
    Thanks!
  2. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    The difference between the two is none except for size mostly.
    Some people are wearing of digital recievers because they are new technology on the market. Some say sound quality is not "as good" as with the older analog recievers.
    If size is a problem the DPR1001 might be the best bet for you, but if you aren't concerned about that then the older analog recievers I think are just as good as the new all-digital recievers.
  3. Norris
    Jul 14, 2002
    201
    Thanks Chris for the input. My budget is about $600 or less, I was set on the AVR 430 but then came across the DPR1001. Hmmmm.
