HK channel level adjustments during playback
Discussion in 'Archived Threads 2001-2004' started by RoyB, Jan 24, 2002.
  1. RoyB
    RoyB Extra
    Jan 22, 2002
    24
    On the lower end HK's (e.g. 220), is it possible to manually adjust channel levels during playback (i.e. without test tones)? [​IMG] or [​IMG] ?
  2. Phil M
    Phil M Stunt Coordinator
    Sep 2, 1999
    161
    I know that you can on the 320 but I don't know how much that helps you.
    For the 320 you simply push the CH. button on the remote and then use the up/down arrows to scroll through the speakers, once at the speaker you want to adjust, you simply press the center SET button and udjust that channels level up or down, then press SET again.
    This is remembered by DSP mode.
    Phil
