HK AVR7200 vs AVR525
Discussion in 'Archived Threads 2001-2004' started by henning hoffmann, Nov 12, 2002.
  1. henning hoffmann
    henning hoffmann Stunt Coordinator
    May 4, 1999
    110
    I've been trying to figure out what the differences are between the AVR7200 and AVR525, and can't come up with anything except power output. Is that the case? Here are the sources I've used:
    http://www.dba-pr.com/clients/harman...es/avr7200.htm
    http://www.harmankardon.com/product_...207200&sType=C
    http://www.harmankardon.com/product_...%20525&sType=C
    The comparison chart (available from the HK links above) shows that the AVR7200 uses a toroidal power transformer vs the 525's EI core. Whatever that means. Anyway, power related, at least. Also, it says that the 7200 uses Cirrus DSP engine, while the 525 (and other receivers, including the 8000) uses Crystal DSP engine. What does that mean? Anything?
    I hope there's more of a reason to buy the AVR7200 than just power.... (like main-ins, Logic7 on 5.1, etc).
    Henning
  2. Kevin C Brown
    Kevin C Brown Producer
    Aug 3, 2000
    5,712
    The 7200 *might* have Logic 7 for 5.1 sources...
  3. Thomas_Berg
    Thomas_Berg Screenwriter
    Feb 28, 2001
    1,422
    Dallas
    Thomas
    i read that the 7200 will not be available for purchase until after christmas, so if that's a factor then just stick with the 525 and use the extra $$ to get a nice multi-channel amp if you need more power.
