HK avr225 0r 230?
Discussion in 'AV Receivers' started by Larry Alan, Oct 13, 2003.
  1. Larry Alan
    Larry Alan Auditioning
    Oct 12, 2003
    9
    I'm in the process of upgrading my old analog Pro Logic receiver to a 5.1 system upgrade. I have heard good reviews of the HK avr225 and have decided it fits the bill for my needs and budget. The question is whether the new avr 230 is a better choice(price is similar). I don't really like it's new look, but I can get over that, if it's better. Has anyone compared these 2 receivers? would you explain the differences?
    Larry
  2. Christian B
    Christian B Agent
    Oct 12, 2003
    46
    One of the main differences is the 230 has 7.1 preamp outputs on the back of it. That's the reason I'm buying it so it can act as a pre/pro for me to run to my Marantz MM9000 when I get it. It has newer DACs as well (digital to analog converters) which are manufactured from Cirrus Logic which are supposed to be a little bit better. I also think the new 230 has 5 watts more per channel. Hope this helps!
  3. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    Actually 5 watts less per channel but still it is a 6.1 reciever instead of 5.1, newer DAC's as well as it offers DTS:Neo6, although not a big deal seeing that Logic7 is offered and I believe it is much better than PLII or Neo6 IMHO. My vote goes to the 230.
  4. Rick Westfall
    Rick Westfall Stunt Coordinator
    Dec 8, 1998
    220
    FYI. You can get a new AVR230 from JandR for $379.88 That includes free shipping
    Rick
  5. Howard_You
    Howard_You Stunt Coordinator
    Sep 16, 2003
    60
    I'd definately go for the AVR230. Besides the 6.1 features, it has pre-amp outputs missing on the AVR225 as well as the triple-crossover bass management (adjustable sub crossover frequency for front/centre/rear channels). One limitation of the AVR225 is the crossover is fixed at 100Hz.
  6. DavidAM
    DavidAM Second Unit
    Sep 30, 2001
    375
    Also doesn't the 230 have video switching? I think I remember seeing that on the HK website when I was checking the new stuff out.
  7. David G Greene
    David G Greene Stunt Coordinator
    Jul 28, 2002
    120
    I use to like Logic 7 better,but lately I like DPL II much better on my HK's. It sounds smoother too me.
