HK AVR125 or AVR225
Discussion in 'AV Receivers' started by Rob E, Nov 20, 2003.
  1. Rob E
    Rob E Extra
    Nov 13, 2003
    20
    After reading alot of posts I have decided to go with HK as my first reciever. I didn't really notice a difference between these two models other than the 10watt increase. Will I hear a distinction between the two models with just 10 watts? Or are there other features that I am missing?
  2. ChrisLazarko
    ChrisLazarko Supporting Actor
    Aug 13, 2003
    867
    No you won't hear a big difference at all, nothing noticeable anyways.
    The big difference I think between the two is the OSD (On Screen Display)... one reason I chose mine over the 125.
    Other than that the difference is really nothing big.
  3. Rob E
    Rob E Extra
    Nov 13, 2003
    20
    What do you mean OSD(on screen display) I am a little confused, can you elaborate? Thanks
  4. ChrisLazarko
    Aug 13, 2003
    867
    On screen display is basically a way of setting up the recievers settings with it displaying it on your TV. It makes it easier for the user... instead of looking at the recievers trying to figure out what commands to put it, it simplifies it a little.
    The AVR-225 does have a couple extra little tid-bits but it's nothing big at all.
  5. Rob E
    Rob E Extra
    Nov 13, 2003
    20
    Gotcha, Thanks
  6. Shaun Graham
    Shaun Graham Agent
    Apr 28, 2003
    30
    The "EZ-Set" feature on the 225 is handy too if you don't have an SPL meter like myself...but I agree with Chris; save the (insignificant) 10 watts per channel and the OSD they're the same. Check out SoundCity for cheap 125 refurbs, they're an authorized dealer, too.
  7. Ian-Fl
    Ian-Fl Second Unit
    Jul 13, 2003
    281
    The 225 has the ezset feature that lets you set the speaker sound levels, doing away with the Radioshack sound level meter.
    I have the avr125 and once I set it up I don't find myself changing the settings. I might toggle between Logic 7 and Pro-Logic II but that's about it.
    I find the avr125 easy to set up without the onscreen display.
  8. ChrisLazarko
    Aug 13, 2003
    867
    I didn't even like the SPL on the HK, it isn't really all that accurate I didn't think..... When it automatically adjusted everything it sounded awful so...
  9. larry mac
    larry mac Stunt Coordinator
    Aug 12, 1999
    171
  10. Mark Murphy
    Mark Murphy Supporting Actor
    Nov 20, 2002
    628
    Another difference is an extra A/V input. That was a deal maker for me. The OSD is a nice little extra, but I hardly use it. I have my DVD and HD STB going directly to my TV, so my Satellite STB, PS2 and VCR are the only inputs I can use with it.
  11. Greg Thomas
    Greg Thomas Second Unit
    May 3, 1999
    438
