HK AVR 525 set-up
Discussion in 'AV Receivers' started by kanian, Nov 12, 2003.
  1. kanian
    kanian Auditioning
    Oct 20, 2003
    9
    Hi guys,
    You've already helped me a couple of times so I'm sure I can count on your expertise again. I've got HK AVR 525 with B&W DM 603 as mains and DM 601 at surrounds. My problem is the equal speakers setup for different input sources. Whenever, I have DVD or satellite or CD input the volume is always different. In addition, when I switch it to DVD the level of center is rather low whereas the fronts and surrounds are relatively higher volume. Is there any easy setup so I can have my center clearly loud so the other speakers don't overshadow it? So far, I haven't configured the system with EzSet, perhaps, I should do it?
    thanks for your help. Adam
  2. Doug Brewster
    Doug Brewster Second Unit
    Jul 22, 2002
    325
    You could use the Ezset but another way is to use the OSD to set your channels. It's one of the options when you punch
    AVR and then
    OSD.
    Navigate down to Channel Adjust.
    Enter it and set it where you want it.
  3. Dave Jewett
    Dave Jewett Agent
    Apr 25, 2002
    34
    Also remember with HK you have different speaker level settings for each input and (I think) each surround mode, so once you find a setting that works for your speakers you'll need to modify the inputs and modes that you use.
    Dave
